Vinusha
How to set a Column list box to required.
My application should allow the users to select the required columns to proceed with further evaluation of the data. And I want to set the column list box status to required. But it is still displaying optional in the modal. How to set them to required.
Button box("X Column", colListX<<Append(colListData<<GetSelected)),
colListX = ColListBox(<<set required(1),nLines(1)),
Button box("Y Column", colListY<<Append(colListData<<GetSelected) ),
colListY = Col List Box(<<set required(1),nLines(1)),
Button box("BY Column", colListBy<<Append(colListData<<GetSelected)),
colListBy = Col List Box(nLines(1))
And I even wanted to display an error msg when the required fields are not selected. Can "Isempty" function used to check whether column list box is empty or not.
Error = expr(New Window("JMP ALERT" , <<Modal, Textbox("Please select the required fields."),ButtonBox("OK")));
If(Isempty(colListX) == 1,
Error
Re: How to set a Column list box to required.
I typically check to see how many items are found after using the messsage
     << Get Items()
Here is an example from the Scripting Index that I did a slight modification to, to find the number of items returned from the Get Items message
New Window( "Col List Box Example",
	Col List Box( all, width( 250 ), maxSelected( 1 ) ),
	fontobj = lb = Col List Box()
lb << Append( "height" );
nitems(lb << Get Items());
You need to use
    << set Min Items()
to set how many items are required for a given list
lb << set Min Items(1);
Use the Scripting Index to find what messages can be passed to the Platforms, along with examples
Vinusha
Yeah, that worked. Thank you so much.
I have another doubt, how can we check whether ColListBox is empty? Can we use "IsEmpty" ? Could you help me with this.
Error
     << Get Items()
Vinusha
