lukasz
How to separate box plot groups with a straight line?
Hello Everybody,
I manage to align data points to corresponding box plots but depending on data there can be more boxes in one group. For interpretation purposes I would like to draw additional lines on the plot that will visually separate each "F" group, like in the right hand picture attached. I would appreciate for hints how to do that. Best regards.picture_3.jpg
Re: How to separate box plot groups with a straight line?
Not sure this is what you want, but if you use Graph Builder and drag the Parameters to the Y axis and Feature 1 to the Group X option and feature 2 to the X axis
you will get the separate areas
lukasz
Hello statman, thank you for your reply, that looks good and I will use that method. However I thought that the main groups F1, F2 and F3 can be displayed in the X axis but now it doesn't matter. I put Feature 2 as color to make differences between subgroups. Redundant legends can be removed. Thank you once again.
