BookmarkSubscribeRSS Feed
davyvy
Community Member
Sep 11, 2016
How to select individual cell based on condition?
How to select individual cell instead of entire rows?
In table below, I need to select the two -99 cells under Value1 and Value2 column, and delete them. Can someone help? When I used select where, the entire row is selected.
test1Value1test2Value2
2531
354-99
4-995443
-8876234
779-763
506545
Thanks
jerry_cooper
Jul 10, 2014
Solution
Re: How to select individual cell based on condition?
Just in case you were looking for a non-scripting approach, you could use search and replace (Ctrl+F), or you could use Column Properties and set -99 as a missing value code. If you use the search option, be sure to leave the Replace With box empty (i.e no space).
Jun 22, 2012
Selecting a single cell, in the context of "Select Where" isn't really available.  But addressing a single cell can be done and then the cell value can be changed, or the cell color can be changed.  Here is an example of how to do this:
Names Default to Here(1);
dt=current data table();
dt:Value 2 << color cells("Red", dt<<get rows where(dt:Value 2 == -99));
Phil_Brown
Mar 20, 2012
davyvy​,
One approach is to simply clear the value of the cell and replace it with missing value (essentially same as delete). So..
:Value1 << Set Each Value( If( Value1[ ] == -99, ., Value1[ ] ) );
:Value2 << Set Each Value( If( Value2[ ] == -99, ., Value2[ ] ) );
I've found that Set Each Value is quite fast. I ran a  test on a 5 column, 6.6M row table and each of the operations above completed in ~2s.
PDB
jerry_cooper
Jul 10, 2014
Solution
ron_horne
Jun 23, 2011
alternatively, you can use the recode option to change the -99 to missing values or whatever value you want. just right click the column from the column list on the left and select recode. the rest is self explanatory.
