Thank you for your detailed feedback,I add some graph for further explain. Can you kindly to help it?
Because I often use the summary function to do some analysis, its better to send the single one instead of separated files, especially there are already a few master files, plus other new generated one... too many files...
P.S. I found there was a case in the help----it has a nested script(run --- Pop a jmp window), I want to know how it was realized...
run the script
