anders_bankefor
How to save a excel file from IE to a specfic location
I have managed to find answers here how to open IE and the website I want to acess, however I would like JMP to open the latest version of the file and save it to path. Any Ideas?
path = "...."
RunProgram(
executable( "C:\Program Files\Internet Explorer\iexplore.exe" ),
options( {adress to a excel file} )
when exicuted it looks like the following:
BR
Anders
Re: How to save a excel file from IE to a specfic location
You should be able to use the open command and the URL directly to return a data table pointer.  Then you can just do a save on the data table.  Something like the following open call worked for me (note this URL is made up, I can't show the real one):
dt = open("http://www.sas.com/testarea/Carpoll.xls");
Brian Corcoran
JMP Development
anders_bankefor
Thank you for your quick response.
I've tried this solution, however it does not open/import the excelfile but rather gives dt a string value with dokument information, maintenance policy regarding the dokument and a HTLM code.
If I use the file > internet open (webpage) it opens a window as I posted before. Is there anyway to automatically (with DLL or other methods) to make JMP "click on view"? I can acess the HTML code if that is any help at all.
Try using Load Text File() function.  I have not tried it in your situation, but conceptually it should read it as a text string.
I tried an example and I couldn;t get it to work.
Craige_Hales
Staff (Retired)
Try
open("http://example.com/path.xls", "Excel");
We probably need to see a little more detail if that doesn't work; check the log for messages too. I'm not sure if the url you have is the url for a page of links to files or the actual file's url.
Craige
anders_bankefor
hi everyone and thank you for your quick responses.
the link or webadress that i insert is not a direct link to a file rather a reference to a folder in a library. The link requiers me to choose a version of the file and if i want to view/edit the file. (the library is missing an API that would give me a direct reference to the file). I will get back to you with a log file.
What I really need is IE automatisation, for e.g i've seen that it is possible to have VBA macros that fills out forms. (mine just needs to find a checkbox and a button)
I will investigate if I can use a socket() as an alternative method.
thank you all for answering my questions.
