mortie999
How to save a Journal to Powerpoint without a Script
I have a Journal with several graphs and tables.  I'd like to save this to Powerpoint such that each table and graph is a different page.  I know I can save the Graph direction to PPT or a Table directly to PPT.  But when I save the Journal as a .ppt, it puts all graphs on one page.  I've see several scripts to do this, but I don't want to use a script.  I'm an infrequent JMP user.  Thank you.
mortie999
Re: How to save a Journal to Powerpoint without a Script
This works great!  Many thanks for your help Stan.
Jeff_Perkinson
What version of JMP are you using?
If you're using JMP 12 or later you can save to PowerPoint directly and it puts one graph or table on each slide.
-Jeff
mortie999
I'm using JMP12.  It does not put the graphs on seperate pages.  All the graphs are on one page.  See attached Journal and saved PPT.
Jeff_Perkinson
Thanks for sharing the journal and powerpoint. That helps a lot.
I see what's going on now. It looks like you're using Graph Builder with a column in the Page role and the Save to PowerPoint isn't considering each of those as a new graph. I think it should. I'll let our development team know and we'll see if we can address it in a future release.
Unfortunately, I don't have a good workaround at the moment but I'll keep looking at it to see if I can come up with one.
-Jeff
mortie999
Thank you for your help Jeff.  Please let me know if/when this gets fixed.
stan_koprowski
If you use the dialog option. And then instead of the page role you can use the by role.
Use Dialog OptionUse Dialog Option
Graph Builder By RoleGraph Builder By Role
Now, if you journal the output and then export the journal to ppt this should give you what you want.
Stan
mortie999
