How to read gz file from URL
I have 1 gz file in URL like http://<<domainName>>/testCSV.txt.gz
how to read it from JMP
Re: How to read gz file from URL
gzblob = loadtextfile("https://drawoutside.com/example.txt.gz",blob());
blob = gzipuncompress(gzblob);
// one way...
text = blobtochar(blob);
show(text);
// another
dt = open(blob,"text");
its able to open file however it showing only first line of file. bt If we unzip manually that file and open we can see data.
We'll need more information.
  • Can you share a file? If not, can you share the log output from
show(length(gzblob));
show(length(blob));
show(left(char(blob),2000));
The goal of the 2000 is to see enough of the first and second line of data to understand what is truncating the file. I'll guess there is a null byte between the lines, and the last show(...) will display it.
  • Are you printing the data to the JMP log or opening a table?
  • Are there any log messages?
  • If we unzip...and open we can see data - what tool do you use to see it? Notepad? JMP? JSL?
  • Are you on Windows or Mac? What version of JMP?
Yes, actually that GZ file itself is CSV each row separated by next line
Are you printing the data to the JMP log or opening a table? -> opening it as table
Are there any log messages? --> log shows on headers
If we unzip...and open we can see data - what tool do you use to see it? Notepad? JMP? JSL? --> if we unzip and open in any editor it will shows all data.
Are you on Windows or Mac? What version of JMP? --> window machine
Without seeing any data it is going to be hard to figure out what you are seeing. The log window picture you supplied stops just short of showing some data. If the data is sensitive, you might want to work through Tech Support rather than posting it here.
What should happen, with a valid xxx.csv.gz file, should look like this
opening a gz compressed csv file into a JMP data tableopening a gz compressed csv file into a JMP data table
