Sburel
How to populate a ColListBox with a list specific columns
I'm trying to build a simple UI in which the user would have the choice between a few specific columns in order to launch a platform. The data table itself has many more columns irrelevant to the platform.
The choice of columns  to populate the ColListBox is known in advance and can be hard coded into a list.
My issue is with finding the correct syntax to use to only display those few columns.
Any suggestions would be appreciated.
Happy memorial day
Sebastien
David_Burnham
Re: How to populate a ColListBox with a list specific columns
You can use the append message
names default to here(1);
lstCols = {"height","weight"};
NewWindow("Test",
	clb = ColListBox(<<append(lstCols))
-Dave
David_Burnham
NewWindow("Test",
-Dave
Sburel
Worked like a charm, Thanks a lot
