lala
Level IX
How to make multi-row dashboards with JSL?
I saved the script for manually creating the dashboard to the data table and closed the data table
Reopening the table and executing the script was unsuccessful.
Thanks Experts!
dt=Open("$SAMPLE_DATA/Big Class.jmp");
p1=dt<< Graph Builder(Transform Column("row",Formula(Row())),Size(500,100),Show Control Panel(0),Show Legend(0),Show Title(0),Show Footer(0),Show X Axis(0),Show Y Axis(0),Show X Axis Title(0),Show Y Axis Title(0),Variables(X(:row),Y(:height)),Elements(Line(X,Y,Legend(5))));
p2=dt<< Graph Builder(Transform Column("row",Formula(Row())),Size(500,100),Show Control Panel(0),Show Legend(0),Show Title(0),Show Footer(0),Show X Axis(0),Show Y Axis(0),Show X Axis Title(0),Show Y Axis Title(0),Variables(X(:row),Y(:weight)),Elements(Line(X,Y,Legend(5))));
Re: How to make multi-row dashboards with JSL?
dt << New Column("col1", Numeric, Continuous, Set Formula(Col Shuffle()));
dt << New Column("col2", Numeric, Continuous, Set Formula(Col Shuffle()));
dt << New Column("col3", Numeric, Continuous, Set Formula(Col Shuffle()));
dt << New Column("col4", Numeric, Continuous, Set Formula(Col Shuffle()));
dt << New Column("col5", Numeric, Continuous, Set Formula(Col Shuffle()));
dt << New Column("col6", Numeric, Continuous, Set Formula(Col Shuffle()));
dt << New Column("col7", Numeric, Continuous, Set Formula(Col Shuffle()));
dt << New Column("col8", Numeric, Continuous, Set Formula(Col Shuffle()));
create_report = function({dt, colname}, {Default Local},
	gb = dt << Graph Builder(
		Transform Column("row", Formula(Row())),
		Size(500, 100),
		Show Legend(0),
		Show Title(0),
		Show Footer(0),
		Show X Axis(0),
		Show Y Axis(0),
		Variables(X(:row), Y(Eval(colname))),
		Elements(Line(X, Y, Legend(5))),
			Dispatch({}, "Graph Builder", OutlineBox,
				{Set Title(""), Image Export Display(Normal)}
	return(gb);
lub = Lineup Box(N Col(1));
cols = {"col1", "col2", "col3", "col4", "col5", "col6", "col7", "col8"};
For Each({colname}, cols,
	lub << Append(create_report(dt, colname));
nw = new window("",
	lub
25 REPLIES 25
lala
Level IX
  • This is the saved JSL
  • Graph Builder(
    	Size( 401, 40 ),
    	Show Legend( 0 ),
    	Show Title( 0 ),
    	Show Footer( 0 ),
    	Show X Axis( 0 ),
    	Show Y Axis( 0 ),
    	Show X Axis Title( 0 ),
    	Show Y Axis Title( 0 ),
    	Variables( X( Transform Column( "row", Formula( Row() ) ) ), Y( :weight ) ),
    	Elements( Line( X, Y, Legend( 5 ) ) )
lala
Level IX
If my data table has 40 columns and I need to make this form of dashboard, how do I script it
Is it necessary to use Application Builder? It might be easier to just build new window and append reports to that
gb_expr = Expr(dt << Graph Builder(
	Size(500, 100),
	Show Legend(0),
	Show Title(0),
	Show Footer(0),
	Show X Axis(0),
	Show Y Axis(0),
	Variables(X(:row), Y(:height)),
For(i = 1, i <= 10, i++,
	lub << append(gb_expr)
nw = new window("",
	lub
lala
Level IX
Thank jthi !
  • Can this name of each window be hidden?
Yes they can. How you might want to do it depends on your application, below is one option using XPath
(nw << XPath("//OutlineBox[text() = 'Graph Builder']")) << Set Title("");
lala
Level IX
  • I still haven't succeeded with the full executable JSL
  • Thanks Experts!
dt << New Column( "col1", Numeric, Continuous, Set Formula( Col Shuffle() ) );
dt << New Column( "col2", Numeric, Continuous, Set Formula( Col Shuffle() ) );
dt << New Column( "col3", Numeric, Continuous, Set Formula( Col Shuffle() ) );
dt << New Column( "col4", Numeric, Continuous, Set Formula( Col Shuffle() ) );
dt << New Column( "col5", Numeric, Continuous, Set Formula( Col Shuffle() ) );
dt << New Column( "col6", Numeric, Continuous, Set Formula( Col Shuffle() ) );
dt << New Column( "col7", Numeric, Continuous, Set Formula( Col Shuffle() ) );
dt << New Column( "col8", Numeric, Continuous, Set Formula( Col Shuffle() ) );
Size(500, 100),
Show Legend(0),
Show Title(0),
Show Footer(0),
Show X Axis(0),
Show Y Axis(0),
(p2 << XPath("//OutlineBox[text() = '图形生成器']")) << Set Title("");
nw = new window("",
lub
(nw << XPath("//OutlineBox[text() = '图形生成器']")) << Set Title("");
lala
Level IX
Report(platform)["图形生成器"]
lala
Level IX
It can be hidden, but how to write multiple columns in JSL is still not successful.
You have to slow down a little bit, explain what you need in small steps. Currently you are asking for multiple different things which all have different solutions as it seems like the goal is changing all the time just a little (makes providing robust solution very difficult).
