See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
jvine
How to make QR Codes
Does anyone know how to make QR codes in jsl?
mmarchandTSI
Re: How to make QR Codes
I call python and do it there using the qrcode module.
To my knowledge there isn't anything native in JMP for creation of QR codes but you might be able to script it depending on your scripting skills. All your base are belong to us (in JSL) might be a starting point. Easier option is most likely to use some QR code API with JMP's New Http Request.
There are some good and bad choices for qr code generators on the web.
My favorite generator is the duckduckgo search engine, just type qr: https://example.com  as the search.
The string can be anything; typically you want the https:// part as well.The string can be anything; typically you want the https:// part as well.
The chrome browser can also share a qr code.
Chrome needs higher resolution. I think the dino in the middle needs extra error checking.Chrome needs higher resolution. I think the dino in the middle needs extra error checking.
A bad generator will produce a code that links back to their site which uses a database to redirect to your site. They will help you collect statistics. And if you failed to understand how it works, they will let you know six weeks later that you'll need to pay to keep the link working (which will be cheaper than re-printing your material...)
This project was useful when I was researching: https://github.com/zxing/zxing
If you still want it in JSL, you can use HTTP Request to a restAPI with something like:
https://goqr.me/api/
The API has really only 2 endpoints and seems straight forward to use.
mmarchandTSI
jvine
Thank you! I would like an offline version that doesnt connect to the web so I think this option would be the easiest/
