I have created a bar chart in graph builder that is formatted as nested bars. I would like to label each data point (3-4 for each nested bar set). I realize this could become visibly cluttered (which perhaps is why jmp does not automatically display them) so I would also be happy if there is a way to label only the largest bar in each data set (dark gray in my graphic below).
I have the "label by value" option selected in graph builder but it does not display the values when using nested bars. Same is true for many other bar types (they do not display even when label by value is selected).
It is easy to label by value with side by side bar chart (see below) but I cannot figure out how to do it with nested bar chart above.
Thank you in advance jmp community and @jmpstopper!
