BookmarkSubscribe
paolo_marco
Community Member
How to get data from an analysis table
Hi all !
This is my first post on these forums!
I'm doing some analysis and I need to do Wilcoxon test on some variable, a lot trust me.
So I was wondering how to extract the data I need most, as P value and other variables.
First I show the code I'm using:
X_var is numeric ordinal, only two groups 0, 1
Y_var is numeric continuous, from 0 to 300
My_cut is numeric ordinal, onyl two groups 0, 1
Oneway(
     Y( :Y_var ),
     X( :X_var ),
     Means and Std Dev( 1 ),
     Wilcoxon Test( 1 ),
     Mean Error Bars( 1 ),
     Std Dev Lines( 1 ),
     Where( :My_cut == 1 ),
          Dispatch( {"Means and Std Deviations"}, "Std Err Mean", NumberColBox, {Hide( 1 )} ),
          Dispatch( {"Means and Std Deviations"}, "Lower 95%", NumberColBox, {Hide( 1 )} ),
          Dispatch( {"Means and Std Deviations"}, "Upper 95%", NumberColBox, {Hide( 1 )} ),
          Dispatch( {"Wilcoxon / Kruskal-Wallis Tests (Rank Sums)"}, "Score Mean", NumberColBox, {Hide( 1 )} ),
          Dispatch( {"Wilcoxon / Kruskal-Wallis Tests (Rank Sums)"}, "1-way Test, ChiSquare Approximation", OutlineBox, {Close( 1 )}
I want to extract the output of means table, for the Y_variable respect the division for X_var == 0 and X_var == 1, and the Wilcoxon output, p-value
I'm asking this since i need to do it a lot of times.
So I'm looking ahead to extract variables and put them into a summary table like this one:
                     N.cases    Y_var mean     Y_var std dev         P_Value
X_var1==0
X_var1==1
X_var2==0
X_var2==1
X_varN==0
X_varN==1
Thanks a lot to everyone !
David_Burnham
Re: How to get data from an analysis table
This recent post is similar and may give you some clues
-Dave
