Neo
Neo
How to get check boxes to be change (or become visible or active) based on a previous selection in a modal window?
In the following script, I would like to do the following:
Based on the selection of TestTech, I want the appropriate TestStage check box list to appear (appear is preferred, if not become active if all options need to be visible). So,
  • if Tech1 is selected, all TestSages with _Tech1 should be available to the user for selection
  • if Tech2 is selected, all TestSages with _Tech2 should be available to the user for selection. This list is commented below
  • if Tech3 is selected, all TestSages with _Tech3 should be available to the user for selection. This list is commented below, and so on.
I would also like "Select All" option to be available under each checkbox list.
How to do this?
Clear Log ();
listInd = {};
returned2 = {};
win = New Window( "Select Tech & TestStage", << modal,
   V List Box (
   tb1=Text Box("Select Tech", << set font style("bold")),
	cb1 = List Box(
		{"Tech1", "Tech2", "Tech3"},
		returned1 = (cb1 << Get Selected());
		listInd= cb1 << Get Selected Indices;
	tb1=Text Box("Select one or more TestStage", << set font style("bold")),
	cb2 = Check Box(
		{"Sage1_Tech1", "Sage2_Tech1", "Sage3_Tech1", "Sage4_Tech1", "Sage5_Tech1", "Sage6_Tech1"},
	    //{"Sage1_Tech2", "Sage2_Tech2", "Sage3_Tech2", "Sage4_Tech2", "Sage5_Tech2", "Sage6_Tech2"},
	    //{"Sage1_Tech3", "Sage2_Tech3", "Sage3_Tech3", "Sage4_Tech3", "Sage5_Tech3", "Sage6_Tech3"},
		returned2 = (cb2 << Get Selected());
	tb3=Text Box("Query TestDate (last 6 months selected by default)", << set font style("bold")),
	end_date = Today();
	start_date = Date Increment(end_date, "month", -6, "actual");
	cb3 =	H List Box(
		Text Box("From:"),
		scal = Number Edit Box(
			start_date,
			<<Set Format(Format("yyyy-mm-dd")),
			<<SetFunction(Function({this}, start_date = scal << Get)),
			<<Set Show Spin Box(1)
		Spacer Box(Size(20, 20)),
		Text Box("To:"),
		ecal = Number Edit Box(
			end_date,
			<<SetFunction(Function({this}, end_date = ecal << Get)),
Technology = eval (returned1[1]); show (Technology);
TestStages  = eval (returned2); show (TestStages);
TestStageOne  = TestStages[1]; show (TestStageOne );
sdt = Munger( Format Date( start_date, "yyyy-mm-dd" ), 1, "T", " " );
edt = Munger( Format Date( end_date, "yyyy-mm-dd" ), 1, "T", " " );
Show( sdt, edt );
Re: How to get check boxes to be change (or become visible or active) based on a previous selection in a modal window?
lb_values = {"Tech1", "Tech2", "Tech3"};
cb_values = {"Sage1_Tech1", "Sage2_Tech1", "Sage3_Tech1", "Sage4_Tech1", "Sage5_Tech1", "Sage6_Tech1",
	"Sage1_Tech2", "Sage2_Tech2", "Sage3_Tech2", "Sage4_Tech2", "Sage5_Tech2", "Sage6_Tech2",
expr_update_cb = Expr(
	cur_sel = lb << get selected;
	cur_cb_values = Filter Each({val}, cb_values,
		cur_tech = Word(2, val, "_");
		Contains(cur_sel, cur_tech);
	cb2 << Set items(cur_cb_values);
win = New Window("Select Tech & TestStage", <<modal,
	V List Box(
		tb1 = Text Box("Select Tech", <<set font style("bold")),
		lb = List Box({"Tech1", "Tech2", "Tech3"},
			expr_update_cb;
		tb1 = Text Box("Select one or more TestStage", <<set font style("bold")),
		V List Box(
			cb2 = Check Box({}),
			H List Box(
				Button Box("Select All", cb2 << Set All(1)),
				Button Box("Clear All", cb2 << Set All(0))
		tb3 = Text Box(
		end_date = Today();
		cb3 = H List Box(
			Text Box("From:"),
				start_date,
			Text Box("To:"),
				end_date,
Edit: Copy pasted originally wrong script
Use associative array to store your different lists, create expressions/functions to create a collector for checkboxes and ifboxes.
This doesn't use modal window, as it is much easier to develop when not using one as you can easily test different gets and such from the script editor
tech_options = {"Tech1", "Tech2"};
stages_tech1 = {"Sage1_Tech1", "Sage2_Tech1"};
stages_tech1_text = {"First Level Tech1", "Second Level Tech1"};
stages_tech2 = {"Sage1_Tech2", "Sage2_Tech2"};
stages_tech2_text = {"First Level Tech2", "Second Level Tech2"};
aa_tech = Associative Array();
aa_tech["Tech1"] = Associative Array(stages_tech1, stages_tech1_text);
aa_tech["Tech2"] = Associative Array(stages_tech2, stages_tech2_text);
get_cbs = Expr(
	cbs = cb_lub << XPath("//CheckBoxBox");
update_checkboxes = Expr(
	tech_selections = lb << get selected;
	cb_lub = Lineup Box(N Col(2));
	For Each({tech_selection}, tech_selections,
		For Each({{stage, text}}, aa_tech[tech_selection],
			cb_lub << Append(Check Box(stage, << Set Function(function({this},
				(this << sib) << Set(this << get);
			cb_lub << Append(IfBox(0, Text Box(text)))
	Try((cb_collector << child) << Delete Box());
	cb_collector << Append(cb_lub);
	V List Box(
		H List Box(
			Spacer Box(Size(0, 300)), // to force height
			V List Box(
				Spacer Box(Size(300, 0)), // to force width
				lb = List Box(tech_options,
					update_checkboxes
				V List Box(
					cb_collector = V List Box(
		H List Box(
				get_cbs;
				If(N Items(cbs),
					cbs << Set All(1, Run Script(1));
				get_cbs;
				If(N Items(cbs),
					cbs << Set All(0, Run Script(1));
			Button Box("Get Values",
				get_cbs;
				If(N Items(cbs),
					cur_selection = {};
					For Each({cb_vals}, cbs << get selected,
						Insert Into(cur_selection, cb_vals)
					cur_selection = {}
24 REPLIES 24
This might give you some ideas what you could do
	If(N Items(cur_sel),
		cur_cb_values = cb_values;
	V List Box(
			expr_update_cb;
		V List Box(
			cb2 = Check Box(cb_values),
			H List Box(
		tb3 = Text Box(
		end_date = Today();
		cb3 = H List Box(
			Text Box("From:"),
				start_date,
			Text Box("To:"),
				end_date,
Neo
Neo
@jthi Thanks. Running your script starts off by showing all TestStages under TestStage by default (pasted below) and then once a Tech is selected, it behaves as needed.
Could the script be modified to not show nothing first under TestStage selection text and then once the Tech is selected, show the appropriate/available TestStages?
You could initialize the check box with empty list instead of cb_values.
Neo
Neo
@jthi  I have already tried with
cb_values = {};
but I think I am not placing this correctly. Where should this statement go?
This is the place where you set those values first time
also if you want it to be always empty when no selections are done you will also have to make small modification to expr_update_cb
Neo
Neo
@jthi . In that case I did place the
cb_values = {};
correctly, but did not do the small modification to expr_update_cb.  Just placing the above line before cb2= Check Box(... does not do what's needed once Tech is selected. Thinking.......
Initialize Check Box with empty list not cb_values (they are different things).
Within the expression this is the part you have to consider (and understand)
Why is if statement used here? What would happen if we go to else? What would happen if we don't have it, we have an empty list and go to Filter Each?
Neo
Neo
@jthi Thanks for the pointers, I tried last night but without success so far.
This is how I understand the requirement, if none of the items are selected in under lb then cb2 should not show. cb2 should show only when N Items(cur_sel) ≥1.
However, expr_update_cb fires only when one or more items are selected in lb.
It is not clear to me how to modify expr_update_cb to be executed when nothing is selected under lb.
Should the requirement of not showing anything under cb2 be handled with an if/else statement around lb i.e. if nothing is selected under lb, do not show cb2?
	V List Box(
			expr_update_cb;
		V List Box(
			H List Box(
		tb3 = Text Box(
		end_date = Today();
		cb3 = H List Box(
			Text Box("From:"),
				start_date,
			Text Box("To:"),
				end_date,
