asukamaru513
How to generate a learning curve plot for surgical outcome?
I would like to generate a surgical learning curve plot like the attached file.
Does anybody know how to generate it by JMP?
dale_lehman
Re: How to generate a learning curve plot for surgical outcome?
This is a strange question.  Are you asking how to produce such a graph or what data do you need?  I'll assume the latter, since producing the graph should be relatively simple if you have the right data.  You will need data on a number of surgeons, their years of experience, and a measure of failed vs. successful treatments of patients over time.  Do you have data like this?  Are you asking how/where you might collect it?  Or do you have data and want to produce the graph?  If it is the last of these, perhaps you can post a sample of your data - or at least say what variables you have data for.
