I used "Contains" to determine the location of the time data, but found it inefficient.
b = Load Text File( "D:\0\Min1.dat", blob() ); // load your file
hex = Hex( b );
last4hex = Right( hex, 8 );
num = Length( b );
last4blob = Blob Peek( b, Length( b ) - 4, 4 );
da1 = "B38DCF77";//B3~8D~CF~77
da2 = "B48DCF77";
off1 = Contains( hex, da1 );
off2 = Contains( hex, da2, -1 );
If( off1,
hex = Substr( hex, off1, Length( hex ) )
If( off2,
hex = Substr( hex, 1, off2 + 1 )
mat = Blob To Matrix( b, "int", 4, "big" );
