ragnarl
Why is the RMSE returned by the Linear Fit deviating the sqrt(sum(residuals^2)/n)?
I am confused regarding the Root Mean Square Error reported in the "Summary of Fit" in the Linear Fit platform.
x = [1.309, 1.471, 1.49, 1.565, 1.611, 1.68];
y = [2.138, 3.421, 3.597, 4.34, 4.882, 5.66];
{Estimates, Std_Error, Diagnostics} = Linear Regression( y, x, <<printToLog );
z=Estimates[1]+Estimates[2]*x;
rmse_lin_reg=sqrt(sum((z-y)^2)/nrows(y));
as table(x,y,<<Column Names({"x","y"}));
biv=Bivariate(
	Y( :y ),
	X( :x ),
	Fit Line( )
rmse_lin_fit=((biv<< report())["Summary of Fit"][Number Col Box(1)] <<get())[3];
show(rmse_lin_reg,rmse_lin_fit);
The result of the last line:
rmse_lin_reg = 0.111508840972607;
rmse_lin_fit = 0.136569881096024;
What is wrong here?
Thank you
jules
Re: Why is the RMSE returned by the Linear Fit deviating the sqrt(sum(residuals^2)/n)?
Hi @ragnarl,
I can see how this appear contradictory! All mean squares involve dividing a sum of squared deviations by their degrees of freedom. In your formula working with the results of LinearRegression() you appear to be dividing by n, not df.
The degrees of freedom for the mean squared error in a simple linear regression is n-2 (1 df lost to estimating the intercept, and 1 more is lost to estimating the slope of x). If you adjust your script as below to have rmse_lin_reg=sqrt(sum((z-y)^2)/(nrows(y)-2)) you will find the same value for MSE (and thus RMSE).
I hope this helps!
@jules
rmse_lin_reg=sqrt(sum((z-y)^2)/(nrows(y)-2));
biv=Bivariate(
	Y( :y ),
	X( :x ),
	Fit Line( )
returns
rmse_lin_reg = 0.13656988109602;
rmse_lin_fit = 0.13656988109602;
jules
Hi @ragnarl,
I hope this helps!
@jules
biv=Bivariate(
	Y( :y ),
	X( :x ),
	Fit Line( )
returns
