lwx228
Level VIII
How to convert text format Numbers to yyyymmdd hh:mm format?
Hello, everyone!
How to use JSL or formula to convert the text of column 1 into the time format of column 2.
Thanks!
Re: How to convert text format Numbers to yyyymmdd hh:mm format?
Here is the formula for the conversion
Date DMY(
	Num( Substr( :date, 7, 2 ) ),
	Num( Substr( :date, 5, 2 ) ),
	Num( Substr( :date, 1, 4 ) ) ) +
	60 * 60 * Num( Word( 2, :date, " :" ) ) +
	60 * Num( Word( -1, :date, " :" ) )
Jeff_Perkinson
@txnelson's formula will work but there's a slightly simpler formula that will work also.
This one uses Informat() to convert the date and time values.
Informat( Word( 1, :Column 1 ) ) +Informat( Word( 2, :Column 1 ), "h:m" )
-Jeff
10 REPLIES 10
lwx228
Level VIII
The column names in the diagram should be
yyyymmdd hh:mm
Date DMY(
Jeff_Perkinson
-Jeff
lwx228
Level VIII
Thanks!
Jim Let me know the principle, Jeff_Perkinson let me learn JMP function.
lwx228
Level VIII
How can JMP get the text of year, month and day from the date format?
Sorry to bother you again,Thank you!
Your question is vague. Please give an example of what the input values looks like, and what you want the output value to be...….
Alina199121
I have one data with one varieble that can inculde diferent types of dates.
Exmple:
17 January 2015
Or
12-6/2013
Or
20.Jan1997
Or
March 26 2001
Or
12-23-1991
They will changed in code.
So, I need to have date in YYYY-MM-DD format in my second variable.
First var is Mdfc
Second Var is Fdtc
Can you help to have the solution?
Thank you !
Here is a format that will work with the examples you provided.  It will have to be tweaked for other combinations of values and structure.  Attached is a sample data table with the formula applied
If( Row() == 1,
	moList = {"January", "February", "March", "April", "May", "June", "July",
	"August", "September", "October", "November", "December"};
	moAbvList = {"Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep",
	"Oct", "Nov", "Dec"};
If(
	Word( 3, :Mdfc, " /-" ) == "",
		theDay = Num( Substr( :Mdfc, 1, 2 ) );
		theMonth = Contains( moAbvList, Substr( :Mdfc, 4, 3 ) );
		theYear = Num( Word( -1, :Mdfc, "abcdefghijklmnopqrstuvwxyz" ) );
		Show( theday, themonth, theyear, Substr( :Mdfc, 4, 3 ) );,
	Is Missing( Num( Word( 2, :Mdfc, " /-" ) ) ) == 1,
		theDay = Num( Word( 1, :Mdfc, " /-" ) );
		theMonth = Contains( moList, Word( 2, :Mdfc, " /-" ) );
		theYear = Num( Word( 3, :Mdfc, " /-" ) );,
	Is Missing( Num( Word( 1, :Mdfc, " /-" ) ) ) == 1,
		theDay = Num( Word( 2, :Mdfc, " /-" ) );
		theMonth = Contains( moList, Word( 1, :Mdfc, " /-" ) );
	theMonth = Num( Word( 1, :Mdfc, " /-" ) );
Date MDY( theMonth, theDay, theYear );
Jeff_Perkinson
The Format() function is used to convert a JMP date, time or datetime value to a text string.
For example:
x=informat("20000214");
show(format(x, "m/d/y"));
show(format(x, "d/m/y"));
show(format(x, "Date Long"));
show(format(x, "Monddyyyy"));
Results in this in the log:
Format(x, "m/d/y") = "02/14/2000";
Format(x, "d/m/y") = "14/02/2000";
Format(x, "Date Long") = "Monday, February 14, 2000";
Format(x, "Monddyyyy") = "Feb142000";
-Jeff
