lwx228
How to convert text format Numbers to yyyymmdd hh:mm format?
Hello, everyone!
How to use JSL or formula to convert the text of column 1 into the time format of column 2.
Re: How to convert text format Numbers to yyyymmdd hh:mm format?
Here is the formula for the conversion
Date DMY(
	Num( Substr( :date, 7, 2 ) ),
	Num( Substr( :date, 5, 2 ) ),
	Num( Substr( :date, 1, 4 ) ) ) +
	60 * 60 * Num( Word( 2, :date, " :" ) ) +
	60 * Num( Word( -1, :date, " :" ) )
Jeff_Perkinson
@txnelson's formula will work but there's a slightly simpler formula that will work also.
This one uses Informat() to convert the date and time values.
Informat( Word( 1, :Column 1 ) ) +Informat( Word( 2, :Column 1 ), "h:m" )
-Jeff
8 REPLIES 8
lwx228
The column names in the diagram should be
yyyymmdd hh:mm
Date DMY(
Jeff_Perkinson
-Jeff
lwx228
Jim Let me know the principle, Jeff_Perkinson let me learn JMP function.
lwx228
How can JMP get the text of year, month and day from the date format?
Sorry to bother you again,Thank you!
Your question is vague. Please give an example of what the input values looks like, and what you want the output value to be...….
Jeff_Perkinson
The Format() function is used to convert a JMP date, time or datetime value to a text string.
For example:
x=informat("20000214");
show(format(x, "m/d/y"));
show(format(x, "d/m/y"));
show(format(x, "Date Long"));
show(format(x, "Monddyyyy"));
Results in this in the log:
Format(x, "m/d/y") = "02/14/2000";
Format(x, "d/m/y") = "14/02/2000";
Format(x, "Date Long") = "Monday, February 14, 2000";
Format(x, "Monddyyyy") = "Feb142000";
-Jeff
lwx228
That's the style,Thanks!
The effect is the same:
format(x, "y/m/d")  ————    format(x, "yyyyymmdd")
Article Labels
