How to change order of labels on nominal x-axis?
Hi -
I have data compared across summer, fall, winter and spring that I would like to plot according to the categories. However, the default is to put the categories in alphabetical order along the x-axis (fall, spring, summer, winter). I would like to place these in order (winter, spring, summer, fall) so it is more logical to the viewer, but I cannot find a means by which to do this. Is there a mechanism for reordering categories along the x-axis?
Thank you,
Dorian
Re: How to change order of labels on nominal x-axis?
Hi Dorian,
Go your column header with the seasonal names and then right click.  Click on column properties and then Value Ordering.  Go to the lower window and move the seasons into the order that you want them to be displayed.
JMP Value Ordering Column PropertyJMP Value Ordering Column Property
Hi Dorian,
acitretin
Worked perfectly for me
Many thanks
Ahmed
Stefan
Thank you for this. Is there a way to change the order within the graph? Eg have 3 graphs, same data, same graph settings, the only thing I need different is the order of the X axis labels?
You're a genius! Thank you.
