DGKim
Can JMP accomplish the Partial Least Squares Discriminant Analysis (PLS-DA) ?
Dear colleagues,
I have read that JMP Pro can perform a Partial Least Squares Discriminant Analysis (PLS-DA) in the JMP manual.
Can I perform the PLS-DA in JMP (not JMP pro)
I would appreciate your responses and consultation.
Thanks
P_Bartell
Level VIII
Re: Can JMP accomplish the Partial Least Squares Discriminant Analysis (PLS-DA) ?
PLS-DA is only supported in JMP Pro.
P_Bartell
Level VIII
