  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
SDF1
How to change only sections of a graph's background color
Hi All,
  I am interested in scripting a solution that allows me to change sections of a graph's background color. I know how to manually do this with editing the axes of a graph, but this changes everything vertically (or horizontally) over that range. I want to change sections that are bounded in both X and Y.
For example, I want to take the following graph and change it from this:
To something like this:
JMP does this with the Process Capability platform and Process Performance Plot, so I'm pretty sure it's possible, but I just don't know how to do it. Preferably, the background colors will change when changing the graph's axes, like it does in the Process Performance Plot.
  Any thoughts/feedback is much appreciated.
Thanks!,
DS
Re: How to change only sections of a graph's background color
The Rect() graphics function can create such colored areas. Be sure to call Rect() before the Marker() function so that the colors do not obscure the points.
Example:
Names Default to Here( 1 );
obj = dt << Bivariate(
	Y( :weight ),
	X( :height ),
	Fit Line( {Line Color( {212, 73, 88} )} ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Add Graphics Script(
				4,
				Description( "" ),
				Fill Color( "blue" );
				Rect( 50, 120, 60, 60, 1 );
Example:
	Y( :weight ),
	X( :height ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
				4,
				Description( "" ),
SDF1
Hi @Mark_Bailey ,
  Thanks for the quick response, that is exactly what I'm looking for.
Thanks!,
DS
lala
Level IX
