News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
Ted
Ted
How to calculate confidence intervals for multinomial proportions?
I have the following data:
20%
30%
40%
10%
Let's say for the type of a some product: a. b, c, d (respectively)
How to calculate confidence intervals for each proportion?
P.S. In this imitation example, we consider (for simplicity) that absolute numbers are also: 20, 30, 40 and 10 (total number: 100)
7 ACCEPTED SOLUTIONS
Re: How to calculate confidence intervals for multinomial proportions?
Try running the distribution script in the attached version of your data. These instructions may also help.
The Distribution platform will provide these intervals in a separate outline. Click the red triangle next to the name of the variable and select Confidence Intervals and the confidence level.
(Using the category age variable in Big Class for an example.)
Re: Re:
Click on the Green triangle next to the "Distribution of Group" entry in the Table Panel on the left side of the data table
Re: Re:
This short video will show how to run scripts from a data table: https://youtu.be/gz1AlTqQg7Q After watching that open the table I attached in my first reply and run the script saved to the table. If the report you get on running the script is the result you are after then open the link I gave in the first reply for instructions on creating the result you are after. This will guide you regarding the steps to take using the Distribution platform to recreate the results you are after.
Kevin_Anderson
I may be mistaken, but I don't believe most of the score procedures for confidence intervals referenced by the esteemed commentators are truly multinomial simultaneous confidence intervals.
If these are really multinomial proportions, I recommend reading the Sison and Glaz article from Journal of the American Statistical Association, Vol. 90, No. 429. (Mar., 1995), pp. 366-369..
Attached is a dataset of your example with some interval procedures compared in the article using formulae.
Kevin_Anderson
Attached, please find the Sison Glaz paper.
And, it might prove useful to have a quick explanation of the confidence intervals in the dataset...
QH = Quesenberrv-Hurst; G = Goodman; FS = Fitzpatrick-Scott
I have experience using the Goodman CIs for multinomials, and not so much with the others.
I'll include the reference for the Goodman intervals in another reply, since I cannot attach two files on one comment.
Kevin_Anderson
The Goodman reference, as promised.
9 REPLIES 9
Ted
Ted
Re:
Thank you, Malcolm! The instruction is important! Since I don’t practice scripts, say a few words, please, how to use your attached file.
Thank you, Mark, for pointing this!
Re: Re:
Re: Re:
Kevin_Anderson
Kevin_Anderson
Kevin_Anderson
Ted
Ted
Re:
Dear Kevin, I am overwhelmed with thanks... You have shown the complexity of this question. Thank you again...
