From the documentation it looks like the * operator will perform a cross product and ;* will perform a dot product. I want to use a cross product to determine the vector normal to a pair of known vectors like this:
3 points define a plane, two vectors taken from those points do the same, the cross-product should give the normal vector of that plane. The problem seems to be that the dimensions of the two matrices being multiplied (v1 and v2) do not agree -- nRows(v1) should equal nCols(v2). I can implement this manually with a simplified formula for vector cross products but does anyone know how to format this differently to work with matrix multiplication?
Created:
Nov 25, 2019 11:23 AM
| Last Modified: Nov 25, 2019 8:58 AM(9582 views)
| Posted in reply to message from CaseyL 11-25-2019
If you're only ever dealing 3x1 (or 1x3) vectors, then I would think computational efficiency or elegance is not too important. Would this be sufficient?
I hope someone comes up with a clever way to do this. The det() function is closely related, but I don't understand how to use det(3x3 matrix) to get back more than a scalar value. I think you could use det(2x2 sub-matrix) three times, but I think the straight-forward xyzzy approach is simpler and just as fast.
Thanks cwillden, this is essentially what I have implemented. It does work for me since I am only concerned with 3D vectors, but I am supprised this isn't a built in function. I'm going to leave this open for a bit to see if anyone else knows of such a way.
Created:
Mar 14, 2023 01:10 AM
| Last Modified: Mar 13, 2023 10:19 PM(8647 views)
Well, the revived zombie caught me. Here is a way to do it via determinants as @Craige_Hales mentioned. It is short, but I don't know... it isn't very simple.
https://mathinsight.org/cross_product_formula shows how the middle element needs to be negative. Above, j will alternate sign (1, -1, 1), and i increases (1, 2, 3). The J(...) function has an implicit loop that evaluates the 3rd argument for each element.
The straight forward corrected formula from @klk is about 3 times faster and about N times easier to understand.
The inferior performance doesn't surprise... thanks for inserting the sign adjustment. I omitted the "sign checkerboard" inadvertently.
IMO this is one of those instances where "just because you can, doesn't mean you should" applies... {cool, fun, short} doesn't outweigh {understandable, maintainable, speedy}.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '236281' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '236281') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '236281') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
