Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
From the documentation it looks like the * operator will perform a cross product and ;* will perform a dot product. I want to use a cross product to determine the vector normal to a pair of known vectors like this:
3 points define a plane, two vectors taken from those points do the same, the cross-product should give the normal vector of that plane. The problem seems to be that the dimensions of the two matrices being multiplied (v1 and v2) do not agree -- nRows(v1) should equal nCols(v2). I can implement this manually with a simplified formula for vector cross products but does anyone know how to format this differently to work with matrix multiplication?
Created:
Nov 25, 2019 11:23 AM
| Last Modified: Nov 25, 2019 8:58 AM(9589 views)
| Posted in reply to message from CaseyL 11-25-2019
If you're only ever dealing 3x1 (or 1x3) vectors, then I would think computational efficiency or elegance is not too important. Would this be sufficient?
I hope someone comes up with a clever way to do this. The det() function is closely related, but I don't understand how to use det(3x3 matrix) to get back more than a scalar value. I think you could use det(2x2 sub-matrix) three times, but I think the straight-forward xyzzy approach is simpler and just as fast.
Thanks cwillden, this is essentially what I have implemented. It does work for me since I am only concerned with 3D vectors, but I am supprised this isn't a built in function. I'm going to leave this open for a bit to see if anyone else knows of such a way.
Created:
Mar 14, 2023 01:10 AM
| Last Modified: Mar 13, 2023 10:19 PM(8654 views)
Well, the revived zombie caught me. Here is a way to do it via determinants as @Craige_Hales mentioned. It is short, but I don't know... it isn't very simple.
https://mathinsight.org/cross_product_formula shows how the middle element needs to be negative. Above, j will alternate sign (1, -1, 1), and i increases (1, 2, 3). The J(...) function has an implicit loop that evaluates the 3rd argument for each element.
The straight forward corrected formula from @klk is about 3 times faster and about N times easier to understand.
The inferior performance doesn't surprise... thanks for inserting the sign adjustment. I omitted the "sign checkerboard" inadvertently.
IMO this is one of those instances where "just because you can, doesn't mean you should" applies... {cool, fun, short} doesn't outweigh {understandable, maintainable, speedy}.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '236281' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '236281') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '236281') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
