Hi @JayC008,
I might be misunderstanding your asks here but perhaps you are seeking additional guidance on some of the data calculations and how to perform them within JMP?
Please clarify if that is not what you are asking as I don’t think your initial choice of data calculations/ platform is where I would start.
For others following along I have included a link to the ICHQ2(R2) guideline.
Based on what I read in section 3.3.2.4 you should be able to use the distribution platform and or the tabulate platforms within JMP for the calculations of recommended data.
Others might have a quick option /platform for generation of the confidence interval using Clopper-Pearson clopper-pearson confidence interval for proportion or with a formula.
3.3.2.4 Recommended Data
“The standard deviation, relative standard deviation (coefficient of variation), and an appropriate
100(1-α) % confidence interval (or justified alternative statistical interval) should be reported.
The observed interval should be compatible with the corresponding precision acceptance
criteria, unless otherwise justified.
Additionally, for multivariate analytical procedures, the routine metrics of RMSEP encompass
accuracy and precision.”
Method validation will need additional documentation of procedures beyond the help and scope of the JMP User community discussion board.
Also, one should demonstrate the Quantitation Limit and Detection Limits for the analytical procedure under investigation.
cheers,
Stan
