  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
How to apply column properties to multiple columns?
Hi Guys,
I am trying to change the properties of about 200 columns to Numeric and Continuous. Is there a way to change the properties of all columns in one shot?
Thanks.
Duane_Hayes
Staff (Retired)
Re: How to apply column properties to multiple columns?
As stated above:
select the columns you want to change and choose "Standardize Attributes" in the Columns Menu. There you can change options for multiple columns.
Dahla
Duane Hayes
8 REPLIES 8
Dahla
Thanks, that worked.
Duane_Hayes
Staff (Retired)
As stated above:
Dahla
Duane Hayes
abdul_saqib
After selecting the columns, I used the following sequence of clicks to change the 'data type' to Numeric ' + ' Continuous: Cols > Standarize Attributes.. > Attributes tab > Data Type
While I could change the 'Data Type', JMP 13.0 did not let me change the 'Modelling Type' to continuous, as it was disabled! I had to do it individually for each column.
Is there a way to change the modelling type too for multiple columns, please? Thanks
If you select all of the columns you want to change, you can then go to the pull down menu
     Cols==>Standardize Attributes
In that dialog, you can change both the Data Type and the Modeling Type.  Make sure you change the Data Type first.  Character data is always Nominal, so if the columns you are attempting to change the Modeling Type are not Numeric, you will not be able to change them to Continuous.  BTW, I assume that is the issue with your latest posting too.
abdul_saqib
Hi Jim,
Thanks for the prompt reply. In order to do a quick test to see if the problem is in the actual data or not, I changed 'numeric/continuous' data of two columns into text (character) data. But, when I tried to change it back to the numeric/continuous, it didn't allow me to do so. (Is it because the data is 'now' nominal as you said, after I changed it to Text Data? If so, it might be the same issue when I was trying to change the other columns in my database).
Thanks
Encl. Screenshots
When changing from Character to Numeric, you need to change the data type first.  You have started that process in your attachment, but you need to click on the "Apply" button, to make that change happen.  Then you can go back and click on the "Attributes" button and select "Modeling Type".
abdul_saqib
Thanks Jim
Yes, it worked now!
So, it's essentially two separate steps one has to follow, when changing text data to continuous numeric in multiple columns:
(1) Cols > Standarize Attributes.. > Attributes tab > Data Type > Numeric
(2) Cols > Standarize Attributes.. > Attributes tab > Modelling Type > Continuous
Or, if one wants to do it in one single step then make sure both 'Data Type' and 'Modelling Type' are checked under the 'Attribute' tab.
Thanks
