Jackie_
How to add label to red reference line?
How can I add label to the reference lines?
Here's my code:
Any advice?
sliderValue = 1;
dothisonchange = Function( {val},
	tb << Set Text( "Cpk : " || Substr( Char( val ), 1, 4 ) )
Mean = 60;
std = 0.5;
New Window( "",
	H List Box(
		V List Box(
			tb = Text Box( "Value: " || Char( sliderValue ) ),
			sb = Slider Box(
				1,
				3,
				sliderValue,
				<<Set function(
					Function( {this},
						sliderValue = this << Get;
						LL = Mean - (sliderValue * 3 * std);
						UL = Mean + (sliderValue * 3 * std);
					//Set the slider and call the other function
						sb << Set( sliderValue );
						dothisonchange( sliderValue );
				LL = Mean - (sliderValue * 3 * 0.5);
			Button Box( "Add Reference line",
				gbfb1 = Report( gb )[Framebox( 1 )];
				gs1 = Expr(
					gbfb1 << AddGraphicsScript(
						Pen Color( "Red" );
						Pen Size( 2 );
						H Line( ::exx = LL );
						H Line( ::exy = UL );
				gs1;
		V List Box(
			gb = dt << Variability Chart( Y( :height ), X( :sex ), Show Range Bars( 0 ), Std Dev Chart( 0 ), Points Jittered( 1 ) );
			gb = dt << Graph Builder(
				Size( 373, 325 ),
				Variables( X( Transform Column( "Row", Formula( Row() ) ) ), Y( :height ) )
Re: How to add label to red reference line?
The Remove Ref Line works fine on my system.  The issue with the Revert Axis is that if anything on the axis has been changed, it will go back to the original setting when the Revert Axis is run.  So if the actual axis range or increments have been changed, the revert axis moves the axis back to the original.  I think the issue you were having is possibly a timing issue, so I have added in a Wait(0) which I believe might fix the issue for you.  Also, you were no longer pointing to the correct charts after you added in the Weight column to the Variability Platform.  After that change, the Output Display structure is changed.  There are now 2 separate reporting branches.
     gb[1]
and
     gb[2]
sliderValue = 1;
Flag = 0;
Mean = 60;
wMean = 105;
wstd = 2;
std = 0.5;
holdLL = LL;
holdUL = UL;
wLL = wMean - (sliderValue * 3 * wstd);
wUL = wMean + (sliderValue * 3 * wstd);
wholdLL = LL;
wholdUL = UL;
New Window( "",
	H List Box(
		V List Box(
			sb = Slider Box(
				1,
				3,
				sliderValue,
				sliderValue = sb << Get;
				gbfb1 = Report( gb[1] )[AxisBox( 1 )];
				gbfb2 = Report( gb[2] )[AxisBox( 1 )];
				//gbfb1 << revert axis;
				try(gbfb1 << remove ref line(holdLL));
				try(gbfb1 << remove ref line(holdUL));
				try(gbfb2 << remove ref line(wholdLL));
				try(gbfb2 << remove ref line(wholdUL));
				wait(0);
				If( Flag == 1,
					gbfb1 << add ref line( LL, Solid, red, "LL" );
					gbfb1 << add ref line( UL, Solid, red, "UL" );
					gbfb2 << add ref line( wLL, Solid, red, "LL" );
					gbfb2 << add ref line( wUL, Solid, red, "UL" );
				holdLL = LL;
				holdUL = UL;
				wholdLL = wLL;
				wholdUL = wUL;
				If( Flag == 0,
					Flag = 1;
	V List Box(
			Y( :height, : weight ),
			X( :sex ),
			Std Dev Chart( 0 ),
See the new code for how the change is handled.
10 REPLIES 10
maybe this: Add Ref Lines to Graphs
Instead of using the Add Graphics Script code, could you use Add Ref Line to work around the issue?
Graph Builder(
	Transform Column( "Row", Formula( Row() ) ),
	Variables( X( :Row ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) ),
		Dispatch(
			"Row",
			ScaleBox,
			{Add Ref Line( LL, "Solid", "Black", "My Label", 1 )}
Jackie_
@Jed_Campbell  Thanks. I want to dynamically move reference lines using slider box. Add ref lines doesn't move dynamically by varying slider box.
I'm not sure if you can move graphics script outside Frame Box, but if you are ok having the label inside FrameBox
You can add Text to your graphic script
Text Color("Red");
Text({0, LL}, "Lower");
Text({0, UL}, "Upper");
The slider script must remove the previous reference line and add the new line when the variable changes.
Here is a rework of the code that uses add ref line to show the dynamic lines
sliderValue = 1;
Flag = 0;
Mean = 60;
std = 0.5;
holdLL = LL;
holdUL = UL;
New Window( "",
	H List Box(
		V List Box(
			sb = Slider Box(
				1,
				3,
				sliderValue,
				gbfb1 = Report( gb )["Graph Builder"][AxisBox( 2 )];
				Try( gbfb1 << remove ref line( holdLL ) );
				Try( gbfb1 << remove ref line( holdUL ) );
				If( Flag == 1,
				holdLL = LL;
				holdUL = UL;
				If( Flag == 0,
					Flag = 1;
	V List Box(
			Y( :height ),
			X( :sex ),
			Std Dev Chart( 0 ),
			Size( 373, 325 ),
Jackie_
@txnelson Remove ref line doen't work. I came up revert axis.
Another question: If say, I'm running 2 variability charts height and weight, I'd like to add reference line to both of them and vary with the slider box. How could I implement that?
Here's the code with revert axis: I want to add ref line to both the variability charts and vary the ref line with slider box
sliderValue = 1;
Flag = 0;
Mean = 60;
std = 0.5;
holdLL = LL;
holdUL = UL;
New Window( "",
	H List Box(
		V List Box(
			sb = Slider Box(
				1,
				3,
				sliderValue,
				gbfb1 = Report( gb )[AxisBox( 1 )];
				If( Flag == 1,
				holdLL = LL;
				holdUL = UL;
				If( Flag == 0,
					Flag = 1;
	V List Box(
			X( :sex ),
			Std Dev Chart( 0 ),
     gb[1]
and
     gb[2]
sliderValue = 1;
Flag = 0;
Mean = 60;
wMean = 105;
wstd = 2;
std = 0.5;
holdLL = LL;
holdUL = UL;
wholdLL = LL;
wholdUL = UL;
New Window( "",
	H List Box(
		V List Box(
			sb = Slider Box(
				1,
				3,
				sliderValue,
				wait(0);
				If( Flag == 1,
				holdLL = LL;
				holdUL = UL;
				wholdLL = wLL;
				wholdUL = wUL;
				If( Flag == 0,
					Flag = 1;
	V List Box(
			X( :sex ),
			Std Dev Chart( 0 ),
