lwx228
How is part of this decision tree interface implemented with JSL?
When Boston housing.jmp is done with a decision tree operation, how do you use JSL to "C2018-08-23_21-30-06.pngopy Table" on a red-box range?Thank you very much!
Re: How is part of this decision tree interface implemented with JSL?
You can copy the table box() to the clip board by using the
obj << Copy Data;
message, where obj is a pointer to the data table in the report output for the Partition Platform.
Here is a simple JSL example.  Once you run this code, if you open a new script window, and paste from the clipboard, you will see the results.
names default to here(1);
nw=new window("xx",
	table box(
		string col box("",
			{"Training","Validation","Test"}
		number col box("RSquare", {.88,.74,.746})
nw[tablebox(1)] << copy data;
obj << Copy Data;
nw=new window("xx",
	table box(
		string col box("",
lwx228
I see. Thank Jim.
