Check the log, there is a missing ; and undefined variable iFrame which you don't need because there is only one frame. The original example embedded the frame number into each script. You don't need the eval(evalexpr(...expr(...)...)) because you no longer have the iFrame to embed in the expr(...)
MouseTrap is the strangest function in all of JMP. When it is called, it does nothing at all. And you don't have to place it where it will be called, but you DO have to place it in the body of the script, not in a user function outside of the script. MouseTrap is a way to supply a snippet of JSL that will run when the mouse moves. When the mouse moves over the framebox, JMP looks for handler functions in the attached graphic scripts and calls them until one handles the mouse.
Yes, one of my code changes was deleted by mistake;
Since my actual generated graph bar graph is very small, using Hover Labels is prone to errors and raises unwanted data.So I still need to trigger the script by clicking on the bar chart. I want to modify it by imitating the script given by the expert earlier in this post.But I studied for a long time, still do not know how to modify.You can only post again to ask the experts for help. Thanks Experts!
