I am curious how JMP organizes data with the Group X function. For this example:
Does JMP simply create groups based on the number of data points?
because your X grouping column is continuous JMP divides the groupings into equal number groups. If the column was ordinal or nominal it would create a grouping for each value found for the column.
For a continuous column in either the Group X or Group Y role, JMP uses quantiles to divide the data into 5 groups.
As Ian@JMP points out, you can right click on the grouping variable label and select Number of Levels to change how many groups are created (still based on quantiles).
Does it use quantiles to divide the data or simply put equal amounts of data into each group?
It uses quantiles.
-Jeff
