yanne
How to export graph to for example EPS without the display box "graph builder" (using JSL) ?
Dear all,
I wrote a script which results in a lot of graphs and reports. I would like to incorporate in my script a way to export some of the graphs (made with Graph Builder) to EPS, JPEG, ... format. I found a way how to do so in the scripting guide (see below) but would like to get rid of the display box on top of teh report --> in my case that is "Graph Builder", in the case of the scripting guide example it is "Bivariate Fit of weight By height". I do not want to change this text to anything else, but get rid of it.  Any tips?
Thanks!!
As taken from the scripting guide:
//This message applies to all display box objects
Open( "Big Class.jmp" );
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Save Picture( "example.png", "png" );
pmroz
Re: How to export graph to for example EPS without the display box "graph builder" (using JSL) ?
Here's one way to do it.  Note that you lose the red triangle.
dt = open("$sample_data\Big Class.jmp");
dt << Graph Builder(
      Show Control Panel( 0 ),
      Variables( X( :weight ), Y( :height ), Overlay( :age ) ),
      Elements( Points( X, Y, Legend( 1 ), Jitter( 1 ) ) ),
            Dispatch( {}, "Graph Builder", OutlineBox, {Set Title( "" )} )
Craige_Hales
Another way:
dt=open("$sample_data/big class.jmp");
gb=dt<<Graph Builder(
  Size( 516, 446 ),
  Variables( X( :weight ), Y( :height ) ),
  Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) )
gb<<showtreestructure; // use this to discover the box you need
report(gb)[picturebox(1)]<<savepicture("$temp/gb.png","png");
open("$temp/gb.png");
Craige
