robbob
How does JMP perform Group X function in Graph Builder?
I am curious how JMP organizes data with the Group X function.  For this example:
  • Temperature is X axis
  • Y is Y axis
  • Condition is used for overlay
  • Measurement is used in Group X
Does JMP simply create groups based on the number of data points?
Re: How does JMP perform Group X function in Graph Builder?
because your X grouping column is continuous JMP divides the groupings into equal number groups.  If the column was ordinal or nominal it would create a grouping for each value found for the column.
ian_jmp
Level X
If you don't like what JMP gives you by default, you can easily make changes. See 'Separate Variables into Groups' at:
http://www.jmp.com/support/help/Add_Variables.shtml#100031
Jeff_Perkinson
For a continuous column in either the Group X or Group Y role, JMP uses quantiles to divide the data into 5 groups.
As Ian@JMP​ points out, you can right click on the grouping variable label and select Number of Levels to change how many groups are created (still based on quantiles).
-Jeff
robbob
Does it use quantiles to divide the data or simply put equal amounts of data into each group?
Jeff_Perkinson
It uses quantiles.
-Jeff
-Jeff
