lala
How do replace these with JSL with regex substitution?
This is copied in the browser. How to use JSL's regular substitution is processed into syntactic JSL with the following requirements:
1, contains POST......HTTP/1.1 replaced with: u="...";h=[=>];
2, containing:, write h
3. The last line..., replace with: jj="...";rs=New HTTP Request(URL(u),Method("POST"),JSON(jj),Headers(h));
POST https://app.com/w1/api HTTP/1.1
Host: apparticle.longhuvip.com
Connection: keep-alive
Content-Length: 87
Accept: application/json, text/javascript, */*; q=0.01
Origin: https://app.com
User-Agent: Mozilla/5.0 (Linux); 5.11.0.6
Content-Type: application/x-www-form-urlencoded; charset=UTF-8
Referer: https://appp.com/w33/community/refreshKey=1696089600
Accept-Encoding: gzip, deflate
Accept-Language: zh-CN,en-US;q=0.8
X-Requested-With: com.aiyu.kaipanla
c=ForumsMsgJX&a=GetInfo&MsgID=30927&Tag=1&DeviceID=ffffffff-e4d8-03bc-ffff-ffffb561792e
11 REPLIES 11
Re: How do replace these with JSL with regex substitution?
What do you need the item count for? Str is a string, not a list so you cannot use N Items on it (you need to use the splitter version which you get using Words()).
lala
  • Thank you. I just wanted a different substitution in the last line
