lala
Level IX
How do replace these with JSL with regex substitution?
This is copied in the browser. How to use JSL's regular substitution is processed into syntactic JSL with the following requirements:
1, contains POST......HTTP/1.1 replaced with: u="...";h=[=>];
2, containing:, write h
3. The last line..., replace with: jj="...";rs=New HTTP Request(URL(u),Method("POST"),JSON(jj),Headers(h));
Thanks!
POST https://app.com/w1/api HTTP/1.1
Host: apparticle.longhuvip.com
Connection: keep-alive
Content-Length: 87
Accept: application/json, text/javascript, */*; q=0.01
Origin: https://app.com
User-Agent: Mozilla/5.0 (Linux); 5.11.0.6
Content-Type: application/x-www-form-urlencoded; charset=UTF-8
Referer: https://appp.com/w33/community/refreshKey=1696089600
Accept-Encoding: gzip, deflate
Accept-Language: zh-CN,en-US;q=0.8
X-Requested-With: com.aiyu.kaipanla
c=ForumsMsgJX&a=GetInfo&MsgID=30927&Tag=1&DeviceID=ffffffff-e4d8-03bc-ffff-ffffb561792e
11 REPLIES 11
lala
Level IX
回复: How do replace these with JSL with regular substitution?
u="https://app.com/w1/api";h=[=>];
h["Host"]="apparticle.longhuvip.com";
h["Connection"]="keep-alive";
h["Content-Length"]="87";
h["Accept"]="application/json, text/javascript, */*; q=0.01";
h["User-Agent"]="Mozilla/5.0 (Linux); 5.11.0.6";
h["Content-Type"]="application/x-www-form-urlencoded; charset=UTF-8";
h["Accept-Encoding"]="gzip, deflate";
h["Accept-Language"]="zh-CN,en-US;q=0.8";
h["X-Requested-With"]="com.aiyu.kaipanla";
jj="c=ForumsMsgJX&a=GetInfo&MsgID=30927&Tag=1&DeviceID=ffffffff-e4d8-03bc-ffff-ffffb561792e";
rr=rs<<Send;txt=blobtochar(Gzip Uncompress(rr));
lala
Level IX
text=Get Clipboard();
txt = Regex(text, "^POST (.+?) HTTP\/1.1\!n", "u=\!"\1\!";h=[=>];");
txt = Substitute(text, "^(.+?): (.+?)\!n", "h[\!"\1\!"]=\!"\2\!";");
Thanks Experts!
Re: How do replace these with JSL with regex substitution?
I would use Words() and split it so I have each of the lines as its own item in a list. Then I would loop over those and build the associative array as I go. Split on ":", first part as key and second as value (format as needed). Last line I would ignore in the loop and build separately
lala
Level IX
  • Thanks jthi! Can you provide JSL? I can only use EmEditor.
This might give some idea
aa_headers = Associative Array();
str = "POST https://app.com/w1/api HTTP/1.1
Connection: keep-alive";
For Each({line}, Words(str, "\!N"),
	rgx_match = Regex(line, "^.*?: ");
	If(!IsMissing(rgx_match), // not the most robust
		aa_headers[Word(1, line, ":")] = Substitute(line, rgx_match, "");
show(aa_headers);
creating a list of possible keys for associative array is most likely more robust if it stays the same
lala
Level IX
  • Continue asking: How can I get the total number of str lines?
Thanks Experts!
Scripting index
and JMP documentation N Items() has the information for you
lala
Level IX
  • I still don't get it.
Thanks!
lala
Level IX
document.selection.Replace("POST (.[^ ]{0,}) HTTP\\/1\\.1","u=\"\\1\";h=[=>];",eeReplaceAll | eeFindReplaceRegExp,0);
document.selection.Replace("^(.{0,}): (.{0,})$","h[\"\\1\"]=\"\\2\";",eeReplaceAll | eeFindReplaceRegExp,0);
