WhiskyNing
How can I find Custom Map Creator Add-In
I fail to find where is Custom Map Creator. I do not know how to open it.
Re: How can I find Custom Map Creator Add-In
Custom Map Creator simple search did find it
after it has been installed (successfully) it is most likely found from JMP Add-In menu
WhiskyNing
I will try, thanku
