UserID16644
Level V
Update column value from another table using wildcard
Hi all, is it possible to update a column from values coming from another table using wildcard as key? I have this example table but doesn't know how to use wildcards properly in updating tables. Also, I am still using JMP 15 version
Table A
Id_AModelStatusStart DateEnd Date
23-ABC-AAADone2023-10-012023-10-05
23-ABD-BBBDone2023-10-022023-10-07
23-ACD-BBCOngoing2023-10-032023-10-09
Table B (file to be updated, start/end date initially has no values, but when their IDs match using wildcard, it will then be updated)
Id_BModelStatusStart DateEnd Date
23-ABCADone2023-10-012023-10-05
23-ABDBOngoing2023-10-022023-10-07
24-AAACDone
Re: Update column value from another table using wildcard
Given the example case you displayed, I do not believe there is a "Wildcard" capability in JMP.  However, you can easily create a new column in table A that has as its value, the first 6 characters of column ID_A.  Then that column can be used to match with the ID_B column in table B.
Depends a bit on what type of wildcard you need what would be easiest. In your example, I would create Id_B column to Table A by dropping the last part of Id_A.
