Frr2
How do I run a knotted regression spline with the 95th quantile?
I am interested in running a knotted regression using the software JMP. However I would like to be able to run a knotted regression using quantiles, specifically on the 95th quantile of the data. Is anyone familiar with how to do this using JMP?
Re: How do I run a knotted regression spline with the 95th quantile?
You might try quantile regression with a spline effect in the Generalized Regression platform in JMP Pro.
Frr2
Thanks Mark,
Do you know if there is a way I can trial JMP Pro?
Regards,
Frank
I suspect the best chance of that, is to contact your JMP sales rep.
I agree with @txnelson's suggestion but if you do not have a sales representative, go to the JMP home Web page where you can access a trial version.
