Geo42
How do I perform cross-correlation in JMP?
I am new to JMP, only using JMP Pro 13 for the past couple of weeks but really enjoying it.  I'm looking for a way to perform cross-correlation but cannot find the tool/function to run it.  I have about 10 variables and would like to find the optimum/most correlated lags between each pair.
Ultimately, if it helps, I'll be performing a step-wise multiple linear regression using the lagged variables...only the lags that show the highest correlations.  One of my variables if the independent variables and the other 9 are the predictors.
Thanks.
David_Burnham
Re: How do I perform cross-correlation in JMP?
First for same sample data: go to help, select sample data library; inside the Time Series folder open SeriesJ.
Analyze>Specialized Modeling>TimeSeries
Put Output CO2 as the Y, Input Gas Rate as the X
From the Transfer Function red triangle select Cross Correlation
-Dave
David_Burnham
-Dave
To add to the information David has provided, I suggest that when you have questions about a specific statistic, that you look in the
     Help==>Statistics Index
There you would have found a description and an example of Cross Correlation
David_Burnham
Or the fun way (requires scripting, or at a minimum a table variable embedded within a column formula):
-Dave
Geo42
Thanks for your help.  I did see the example but couldn't figure out how to get the Tranfer Function Analysis red arrow.  I just figured it out though...you need to put one variable in the "Y, Time Series" and another variable in "Input List", then cross-correlation option becomes available.  If you put both/multiple variables in "Y, Time Series" only, cross-correlation is greyed out...but most other functions work fine though.
Is there an option for a triangular display similar of cross correlations among variables, similar to the displays for multivariate scaterrplots?
Thanks again.
For this one, you deserve an extra crumpet with your tea!
