So I noticed that others had the ability to hover over things and a text box would appear with info about the object.
The āhover textā pop-up that you get when you hold the mouse over a field.
However I seem to be missing it, when I hover over stuff nothing pops up, is there way to enable it?
I'm using JMP 13.
Here's an example of the hover text:
