lwx228
Level VIII
How can I open a JMP file without leaving a record in the From list?
For example, open "Big class.jmp ",
Can add code to JSL's open code to keep it out of the From list?Or use JSL later to delete "Big Class.jmp"'s records from the From list?
dt = Open( "$SAMPLE_DATA/Big Class.jmp";??? );
Re: How can I open a JMP file without leaving a record in the From list?
I think this is what you are asking about. I find it really useful when I'm opening a lot of files, it prevents the ones I care about from falling off the bottom of the list!
Add To Recent option in Open( ) functionAdd To Recent option in Open( ) function
lwx228
Level VIII
Thank Craige!
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp",Add to Recent Files(0) );
gzmorgan0
Another option, especially if you are scripting, is to open the file as Private. Then the file does not appear in the From list nor the Windows List.
