tkutch
TOST Equivalence Test error
I followed the Equivalence Test (TOST) example but the output is different from the website.
https://www.jmp.com/support/help/en/15.1/index.shtml#page/jmp/example-of-an-equivalence-test.shtml#w...
Website:
>= 6 p=0.0124
<= -6 p<.0001
My output:
<= 6 p=0.0124
>= -6 p<.0001
Essentially, the null hypotheses have been reversed so that rejecting corresponds to non-equivalence. The hypothesis on website appear accurate as rejecting the null indicates evidence that data is within the equivalence region. Why is my software reversing the hypothesis?
I am using JMP 13.2.0
Re: TOST Equivalence Test error
JMP uses alphabetic or numeric order by default except for a few special cases. Gender is not one of them. So the default order is F is first and M is second. That leads to the results shown in the on-line documentation.
This order is important. JMP will subtract the response of the second level from the response of the first level, so the mean height of sex = F from the mean height of sex = M.
If the order of the sex levels is reversed, then so is the difference (negated). I was able to reproduce your result by adding the Value Order column property and making M first and F second. Is that what you have for the order?
tkutch
@Mark_Bailey I have F first and M second in the Value Order column property. I tried switching the order (M first, F second) and yes the mean difference flipped, but the null hypothesis are still <=6 and >= -6.
I see. I cannot remember if the labelling of the null hypotheses was an issue in JMP 13. You should report this behavior to JMP Technical Support ([email protected]). Please report here what you learn from them.
