BookmarkSubscribeRSS Feed
yannntima
Community Trekker
Aug 2, 2016
How can I do a PDF files with Jump
Hi all,
In fact I have a small issue because I want to do a PDF file with JMP that can be a summarized of some graphs (save in datas table JMP) and a table from some greatness of Analysis (average, sigma, min and max).
ex :
So I want do for each graph his tableau and put that on a PDF file.
I put in attachement my JMP file.
NB : the present table does not correspond to the graph above.
Thanks for the help.
Yann N.
Dan_Obermiller
Apr 3, 2013
Solution
Re: How can I do a PDF files with Jump
Or, instead of printing the journal as PDF, you could just do a Save As of the journal and choose PDF.
Dan Obermiller
guillaumebugnon
Community Trekker
Apr 7, 2015
Hi Yann,
You can put both analysis into a journal and print the journal to pdf.
Regards,
Guillaume
Dan_Obermiller
Apr 3, 2013
Solution
Dan Obermiller
stephen_pearson
Community Trekker
Oct 6, 2014
Hi Yann,
I use the script below so I don't have to specify the details each time I save the pdf.
  1. Create a journal
  2. Send my graphs to the journal
  3. Add a save pdf button which has my preferences specified (you will need to experiment with the margins and scale factor)
  4. Press the button to generate the pdf
Note: if the folder for the save location doesn't exist or JMP can't write to it the script will fail but not warn you.
Use: Current Journal() << Append( H List Box( Page Break Box(), ) to start a new page.
Regards,
Stephen
//set file properties
//(if location doesn't exist or JMP can't write to it the script will fail silently)
SaveLocation = "C:\Reports\";
Author = "My Name";
Title = "My Report";
//Create a journal to recieve the output
ResultWindow = New Window( Title, <<journal );
//add output
  Graph Builder(
  Size( 534, 500 ),
  Variables(
  X( :Prototype ),
  Y( :Name( "Sucre 1/3 [%]" ) ),
  Y( :Name( "Sucre 2/3 [%]" ), Position( 1 ) ),
  Wrap( :Voies )
//add a save button to the Journal Window
  H List Box(
  Button Box( "Save As PDF",
  thisWin = Current Window();
  thisWin << Set page setup(
  margins( 0.4, 0.4, 0.7, 0.7 ),
  scale( 0.7 ),
  portrait( 1 ),
  paper size( "A4" )
  thisWin << Set Print Footers(
  Author/*left*/,
  "&d;"/*center*/,
  "Page &pn; of &pc;"/*right*/
  path = SaveLocation || title || Char(Long Date( Today() )) || ".pdf";
  thisWin << Save PDF( path );
yannntima
Community Trekker
Aug 2, 2016
Thank you for the support, I think I have what I looking for. I wil try each solution.
Yann N
