Hello JMP community,
I am having issues generating an automated high resolution PDF from my Control Chart JMP Reports or Journal. (Attached) As you can see attached the PDF is heavily compressed. I have looked throughout the forums with no results.
I updated the DPI setting in preferences to 300. I even installed this add-in from danielvalente to verify the DPI:
 https://community.jmp.com/t5/JMP-Add-Ins/Set-Output-DPI/ta-p/22486
1) Save AS PDF results in low DPI
2) Print as PDF via Adobe or Microsoft results in low DPI
3) Same results if I convert the report to a Journal first.
4) Histograms seem to export at the correct DPI, Control charts are having the issue.
5) My only success was from the following post where I export a EPS file then use a 3rd party program to convert the PDF at 300 DPI. I would like to avoid this scenario as my clients are hesitant to install any 3rd party software.
https://community.jmp.com/t5/JMP-Blog/Print-ready-graphics-from-JMP-revisited/ba-p/30122
Look forward to any responses and thank you in advance.
