Headings disappearing
I am just getting started with JMP. I am noticing that all the headings within the Distribution window disappear when I hover my mouse over them.  If I resize the window slightly, they reappear.  Is there any way to stop this from happening?  I would prefer the headings to show all the time. It's really tough to select the little red triangle without them.
I have a MacBook Air M1, running Ventura 13.2.  This is version 17.0.0 of JMP.
These are screenshots with and without the headings showing:
Screenshot 2023-02-01 at 8.52.22 PM.pngScreenshot 2023-02-01 at 8.51.22 PM.png
stan_koprowski
Re: Headings disappearing
Hi @GeneratingModes,
Welcome to the JMP Community.
This issue has been reported and is fixed in the JMP 17.1 release.
It is recommended if you are running Mac OS Ventura 13.x to update to the latest JMP release when available.
The JMP 17.1 maintenance release will be available in Spring of 2023.
cheers,
Stan
stan_koprowski
cheers,
Stan
Thank you for your response, Stan. Is there a way to install a previous version of JMP as a workaround?  I am using JMP as part of a university course this semester.  I suspect my class will be over before the next version is released.
Regards,
Brian
