Created:
Nov 3, 2021 01:27 AM
| Last Modified: Jun 10, 2023 4:39 PM(4077 views)
I am working on a graph of Voltage vs Current. I have my y axis (current scale) set to log and i want to change the scale to the format 10e-2 (for example). Everytime I try to do this, the graph scale to 1e-1. I need the scale to be in the notaion 10e not 1e. Can anyone hlep with this?
Good question because it took me a while to figure out how to do that interactively too. If you type the upper bar character '|' in the formula editor you will first get the or symbol, then if you type it again you will get the concatenate operator '||'. Also, if you double click on the formula it will open a text editor where you can type the two upper bars.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '432376' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '432376') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '432376') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
