Vvvv
Divide column by reference point with conditions
Hi. I have a problem I can't get my head around.
I am trying to create a new column which consists of another column divided by a reference point, but the problem is I have some conditions to include.
For simplicity I have added a generated datafile which I will refer to.
What I want to do is to take column Z and divide it by Z|X=c within each Y-group. The Y-groups are as you can tell not the same size.
SO C is the reference point, and for all Y-groups (1-9) I want to take column Z, and divide it by Z|X=c.
That is, in the new column all values where X=c will be 1 and the others will be Z / (Z|X=c).
I apologize for not being able to formulate myself in clearer terms, for various reasons I can not show my real dataset and English is not my native tounge.
Any help is greatly appreciated.
V
Re: Divide column by reference point with conditions
Here is one formula that works
currentY = :Y;
:Z / :Z[(Current Data Table() << get rows where( :X == "c" & :Y == currentY ))[1]];
currentY = :Y;
Vvvv
Haha this was way easier than I thought it would be.
Thank you very much.
