I am currently working on a JMP Pro data file (attached), which contains 150 observations covering the years 2015 to 2024. The dataset comprises four columns: “YEAR”, “Location”, “ENT CAP”, and “NEP”.
I would like to organize the data by grouping all rows according to the values in the YEAR column. For example, all 16 rows corresponding to 2015 should be grouped under the label “Y2015”, and similarly for subsequent years—“Y2016”, “Y2017”, up to “Y2024”.
In addition, I would like to group the data based on the Location column. This should result in separate groups such as “Europe”, “America”, “Asia”, “Africa”, etc., depending on the regions represented in the data.
Could you please advise on how to perform both the year-wise and location-wise grouping in JMP Pro 18?
