rugolf
Graphiques dans les marges d'un nuage de points
Il peut être intéressant dans un nuage de points de rajouter pour chacune des deux variables et dans les marges une boite à moustaches ou un histogramme.
Je n'ai pas trouvé, est ce possible ?
Par avance merci.
Re: Graphiques dans les marges d'un nuage de points
In graph builder you can do it with some workarounds and you can already do it in Fit y by x (Bivariate) by enabling Histogram Borders
There might also be some wish list items regarding this but I'm not 100% sure about that
And this is what you can do in Graph Builder but to my knowledge you basically have to add placeholder columns as extra x- and y-axis
rugolf
merci, ok pour les histogrammes en bordures mais pouvez vous me donner quelques explications avec le graphe builder
Add Nominal Transform Column to your Graph Builder with formula with just value 1 and rename if you want to
Add that new Nominal column as extra column to both X and Y Axis
Disable plot (and other) plots for those placeholder graphs and add distribution for those. You can do this by holding ctrl+shift and clicking different plot types from corners
From the AXIS between different columns you can adjust the proportions
Cleanup the plot: edit those placeholder axis to hide labels, titles and legend items
