BookmarkSubscribeRSS Feed
jort
Community Member
Jun 23, 2011
Graph "Arrange With Data Table" via Script?
Hello, fairly new to JMP. Got as far as loading a table from a Stored Process, and I have a graph against the data that I like. Is there a way for my script to execute the "Arrange With Data Table" to get my table/graph side-by-side?
Thanks in advance!
jschroedl
Jun 23, 2011
Unfortunately, with all the scriptability of JMP, this is one of the pieces which is not currently scriptable.
ron_horne
Jun 23, 2011
when wanting to ad the data table into the output I found this post very useful:
https://communities.sas.com/message/114035#114035
this will enable you to convert the data table into a table list box quite simply.
joneseven
Dec 4, 2011
Re: Graph "Arrange With Data Table" via Script?
Hi jort
JMP 9 can do what your said ,click the arrange menu at the right-down of your drop.
ms
Jun 23, 2011
I am not sure if you mean arranging the different windows side by side, or if you want them side by side within the same report window.
The first situation could be scripted like in this example:
dt = Open( "$ENGLISH_SAMPLE_DATA/Big Class.jmp" );
ow = Oneway( Y( :height ), X( :age ) );wait(1);
graph_pos=ow<<get window position;
graph_size=ow<<get window size;
table_pos=dt<<get window position;
table_size=dt<<get window size;
// play around with the table size scaling factors (1.5 & 1 times the graph's width & height resp.)
// below to get the desired result
dt<<set window size(graph_size[1]*1.5,graph_size[2]*1);
ow<<move window(table_pos[1]+graph_size[1]*1.5,table_pos[2] )
The second situation could be solved in different ways, here is one approach:
close all(journals);
dt << journal;
New Window( "test", H List Box( Current Journal()[1], Report( ow )[1] ) );
// Clean up workspace
Current Journal()<<close window;
ow<<close window;
