BookmarkSubscribe
agriego
Community Member
Graph builder data labeling
I am new to JMP and I have a question about the graph builder. I am comparing data of multiple columns and I would like to label or highlight specific row and column values. However, when i pick a point on my graph it references all the column values in that row. Is there a way to label the specific value that I want and not all the values within that row?
I am using JMP 10.
Thanks for your time.
Aaron Griego
XanGregg
Re: Graph builder data labeling
Hi Aaron,
It's usually a benefit when properties are tied to the rows and reflected in multiple uses of each row (that's what allows brushing and linking to work), but here it's getting in your way. The only work-around I can think of is to use the Annotate tool and manually make a annotation for each such point.
